foreigner 0 Posted April 18, 2007 I got quicks*it fitted as mentinoned in my other thread. When I was swapping lever on the box for one to fit quickshift the lever shaft went slightly into gearbox. Could this cause some internal change in box to not be able to select reverse gear in. Or should I just play with rods to see if it heals? Guys any help ? Share this post Link to post Share on other sites
allanallen 528 2 Cars Posted April 19, 2007 Could this cause some internal change in box to not be able to select reverse gear in. yes, you've probably lost fifth aswell. i swapped my box when i did this but i'm sure you can fix it, sure someone can spread some light on it. Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted April 19, 2007 that happend to me too, the round round thingy dropped into the box, its a right bitch to sort out, i had to fiddle with it for about an hour lifting it droping it twisting it untill it finaly went to where it needed to be, then when i went to re-fit the lever it fell again, a right hastle!!! but evemtuay got it sorted Share this post Link to post Share on other sites
foreigner 0 Posted April 19, 2007 (edited) SORTED. I got piss*d off, took angle grinder to my other box. cut half of it off. straighten it, drilled three holes and bolted that terrible thing together, i'll see if it works, it should. Edited April 19, 2007 by foreigner Share this post Link to post Share on other sites
DamirGTI 344 Posted April 19, 2007 Hi ! Same thing happend to me reacently see this : http://forum.205gtidrivers.com/index.php?s...hl=reverse+gear Share this post Link to post Share on other sites
mbayley77 0 Posted April 19, 2007 Its taken me 9 months so far to even think about trying to sort this b@stard problem on my car. hence its still in t6he drive with 1 mile on a brand new engine. really shoul pull my finger out! Share this post Link to post Share on other sites
foreigner 0 Posted April 19, 2007 (edited) Hi ! Same thing happend to me reacently see this : http://forum.205gtidrivers.com/index.php?s...hl=reverse+gear i know i've read your topic. have a look at mine about Diesel GTi there is picture about what i've done I was lucky i got spare engine and box. Edited April 19, 2007 by foreigner Share this post Link to post Share on other sites
