willxs 0 Posted April 17, 2007 i know the S16 seems to use the complicated-to-fit pull clutch system with the bearing pressed into the housing. now im going to be using the mi16 gearbox as i know its alright. question is, is there anything i need to swap over from box to box? i.e. the forks? or could i just use a normal style clutch? lose bearing sort to make it easier? reason i ask is i dont understand why its different, bearing pressed in or not as there is nothing obvious? Cheers, Will Share this post Link to post Share on other sites
Alastairh 47 Posted April 17, 2007 You'll need: Mi16 box, Mi16 clutch with bearing, and obviously the smaller gear selector arm for a 205 Share this post Link to post Share on other sites
willxs 0 Posted April 17, 2007 great stuff! cheers for that! Just means ive got to go swap it back at gsf! Share this post Link to post Share on other sites
