Rob_the_Sparky
Weeping Power Steering Union
Rob_the_Sparky
My car failed the MOT on this (amongst other things) despite me not noticing any loss of fluid. MOT man said it was minor but anything was enough for a fail on the power steering.
Any suggestions what to do? Is there anything replacable in these unions or is the only choice "do it up tighter"?
Rob
Edp
Dosent look like theres any washers or consumables where the pipes join the ram ^_^
just a do it up tighter jobbie, not too tight of course, and a bit of copper grease on the threads and where the union turns and clamps the pipe helps a lot.
saveloy
The PAS on my mum's old 309 GTI weeped a little, close to the ram. Unfortunately it was too far gone and the actual ram had to be replaced.
There is a small bush that can fail and cause a small weep. You may be lucky enough to have caught it in time.
Rob_the_Sparky
If it comes to that then I think it would be time to remove the PAS!
James_m
Mine was leaking at the same place. I think the threaded unit part has worn out, as know amount of o rings help. Ive had enough and am binning PAS :)
Edited by James_m
