matt-k
What Engine Sealant Should I Use?
matt-k
Hi, could someone please tell me what the best engine sealant is to use that wont perish in oil and high temperature etc? Ive heard that standard silicon sealant wont work. :D
Cheers, Matt.
Mikey S
Hi, could someone please tell me what the best engine sealant is to use that wont perish in oil and high temperature etc? Ive heard that standard silicon sealant wont work. :P
Cheers, Matt.
what are you actually going to seal with it?
Edited by pugger
Sandy
I use Loctite 5966 (Grey) mostly. It's adhesive enough to stay put, but comes apart again ok. Assuming the joint is resonably tight, it's excellent.
matt-k
Thanks for that mate :P
Ill be using it around the bottom end on the casing seals for extra peace of mind really! as im starting the rebuild today, hopefully!
