GazRallye
Mani Down Pipe
GazRallye
I have just posted this
http://forum.205gtidrivers.com/index.php?s...mp;#entry677085
but looking on GSF, they are listed as the same 1.0, 1.1, 1.4.
The blocks are different heights so on TU ax, a 1.1 won't fit onto a 1.4
Can anyone confirm if a downpipe from a 205 junior will fit a my xs??
swordfish210
if you're really desperate for a downpipe i have a nearly new one with manifold from a 205 rallye (UK spec) sat at college doing nothing that you could buy from me? drop me a PM if you're interested
Casanova
I've done this before and had no problems (robbed lots of bits off my old Junior for the XS). Had the two downpipes off and sat next to each other and they didn't look much different - the flatter bottom of the XS one was the main difference. I think they're freely interchangeable.
GazRallye
Cheers swordfish, might take you up on that offer
I noticed the flatter bit on the xs one, thought it had either been crushed on a speed bump or that someone had bodged one from a smaller engine model and had to squash it to get it to fit under the sump! But if they're like that new, then fair enough!
Did it line up with the rest of the exhaust ok then?
They are marked as different part numbers, so there must be some difference...
Casanova
No probs lining up. Of course, the one off the Junior might not have been original fitment for all I know...
Jrod
Out of all the phase 2's I've had none had that flat bit, only the phase 1.5 did.
GazRallye
There was an F reg XE in the scrappers, would that be a 1.4? It had the flat style bit
Don't know what phase mine is, its a H plate built in '89 registered Jan '90
GazRallye
Sorted, the one off my mates crashed 'style' does fit
