Richie-Van-GTi 74 2 Cars Posted April 13, 2007 just a quicky, will a 4 wire lambda work if only the sender wire is attached? I know it will take a while to heat up from exhaust gases but not sure if the other wire will cause problems? Share this post Link to post Share on other sites
mbayley77 0 Posted April 13, 2007 try this here. or contact them http://www.lambdapower.co.uk Share this post Link to post Share on other sites
petert 601 Posted April 14, 2007 just a quicky, will a 4 wire lambda work if only the sender wire is attached? I know it will take a while to heat up from exhaust gases but not sure if the other wire will cause problems? Yes it will work fine providing it's in the down pipe, close to the engine. It won't work at at low RPM however (<1500) as there won't be enough heat from the exhaust. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted April 14, 2007 it will be at the end of the downpipe as I have a 4 branch on the car, closest place I can get it is about level with gear lever. Share this post Link to post Share on other sites
