chris 417 mi
[engine_work] Mi16 Engine Bay Tidy & New Head Fit !
chris 417 mi
Been wanting to sort my engine bay out for years but never had the time/tools/ courage to start taking thigs apart ! :wacko:
Last year i did my first mi conversion on another car so now its my blue pugs turn !
I didnt fit this engine it was done for me by a local garage about 5 years ago, the throttle bodies were also fitted for me and the current big valve head again fitted by a certain company whom i wont mention but am not very happy with, as it has never give the power it was supposed to :) .....but never mind cos i have a new standard head with cat cam on the way from QEP ;)
made a start last sunday and here's the progress so far :
Bonnet off and on axle stands
starting to strip throttle bodies out, lots of parts to keep together !!
All the wiring :ph34r:
Edited by chris 417 mi
chris 417 mi
Bodies out with henry looking smug :ph34r:
All that free space!!
And again
draining oil to remove shafts, Pain to remove drain nut when your gear box was powder coated :wacko: , nice and easy to clean though ;)
chris 417 mi
Getting driveshaft ready to come out
And the other one, sooo easy with an impact gun, best thing i ever bought ;)
These shouldered bolts on the longer drivers side shaft hold the middle bearing in, i tightened them 'open' so they dont get lost and are well out of the way whilst removing the shaft
Now for the radiator, i took all the higer pipes off first then carefully drained the water out of each pipe working highest to lowest at the front of the engine (still got water everywhere though :wacko:) best leave the rear colant union at the back of the block till all fron pipes are off and theres less chance of gettin soaked where you cant get out quick :)
All pipes now out ! gotta start on the gear linkages and finally the dreaded exaust manifold
Oh and does anyone have any ideas how i should lift this out ...bearing in mind someone has kindly decided to remove all the lifting eyes from the block :ph34r:
kyepan
are those nissan calipers?
chris 417 mi
nope bremsport mate, got em off a lad who had them on a 205 rallying / track car
chris 417 mi
Ok the engine & exhaust manifold are now out ! didnt manage to get any pics of it during removal but heres what i did get
Engine on stand and the small mountain of parts ive removed so far
Gearbox needs a good clean !
Engine needs a good clean, would of liked to get it powder coated but would mean a total strip down :blink: , painting will do for now :D
and again
chris 417 mi
Lots of rust to see now, gonna have the full bay painted and rust treated
and again on closeup :blink:
Looks like waters got in here too :)
Part of the alarm wiring :D looks like it was joined by ...err.....twisting together and a bit of luck :D
One of the inlet ports, apparently 'ported' but isnt this supposed to be very smooth ?? looks like it was done with a rough flapper wheel
chris 417 mi
just about done for the night, all wiring out of the way ready for painting. Got a few more pipes to move though
And final shot for the night, sorry for the blurryness :blink:
Edp
Looking good. A nice late car you have there.
Keep the pictures coming. By the way where on earth are going to fit a henry hoover in the small 205 engine bay? ^_^
chris 417 mi
havent you heard ?? he got voted best co pilot ever :D
Richie-Van-GTi
wahey, about time chris. Think mine will be done before yours. By end of this week I will have everything required to finish mine ^_^
Mikey G
Thats normal, rough surface adds to the mixing of the fuel/air.
Keep it up ^_^
chris 417 mi
Keep it up :D
Ah right, i always thought it would be polished to a fairly smooth finish ^_^
Cheers :P
5150maxie
the number plate says it all :o
chris 417 mi
the number plate says it all :D
strangely enough a few rac people have asked to buy it off me :)
chris 417 mi
Did a bit more last night ready for the weekend
Engine bay is now totally stripped and ready for painting !
side view (gotta get a better camera phone :o )
View of the cams, funny thing is the timing marks are way off ! inlet cam is almost exactly on the white timing mark someone has put on ...but the exhaust cam is almost a quarter of a full revolution out :) anyone shed any light on this cos ill be taking the head off very soon !
The cams were probably timed using the lift at TDC method. Timing marks can become irrelevent when aftermarket cams and pulleys are used.
chris 417 mi
:) right ok , err guess id better get someone who knows how to retime the engine when its going back together then :)
just set it to TDC with the crank pulley locked and put some timing marks on the cam pulleys and you should be able to get it pretty close.
Locking the crank pulley is 90 deg. BTDC, pistons half way up and half way down.
chris 417 mi
All i was gonna do was just remove the belt as it is now clean and pain the engine then take it somewhere to get timed, unless anyone can show me the extact points etc cos i really dont want to bugger a new head ! :huh:
Gavtrials
So jelous of the double garage!
Wish i had that and not just a drive to work on!
chris 417 mi
:huh:
Richie-Van-GTi
chris I'll come down one night during the week and show you how to time it with the new head, well enough to get it running. Timing wont be bang on as your having new cams with different durations and lifts.
chris 417 mi
Cheers mate :ph34r: thanks for the help on sun morning too !
Some more pics
Off to the spray shop on sun morning (once again cheers to richie for the tow :lol: )
And again
Engine block starting to get a good jet wash down
Rear now as clean as i could get it with the time i had
