dch1950 37 1 Cars Posted April 12, 2007 Hi All, I am currently trying to second source these precious little rivets and have written directly to Peugeot to obtain the part spec (and hopefully any help they care to offer.) I am also contacting 2 fixing manufacturers to see if the can adapt any of their current rivet designs. This is probably a totally cost ineffective exercise but they are so fundamental to any 205 refurb it seemed worth pursuing. Will get back to you all when I get any feedback.Wish me luck. Dave Share this post Link to post Share on other sites
Grim.Badger 15 Posted April 13, 2007 Try Vauxhall Calibra trim rivetts, apparently they are the same. Share this post Link to post Share on other sites
Ryan 99 Posted April 13, 2007 Apparently they are only no longer available seperately. If you buy the kit with all the trim clips in then it includes the rivets too. Share this post Link to post Share on other sites
KaspaCti 0 Posted June 15, 2007 Try Vauxhall Calibra trim rivetts, apparently they are the same. Sorry to resurrect an old post but thought it might be useful. I've recently bought some rivets from vauxhall which are identical to pt no 8472.20. There are two numbers listed on my invoice, as I'm not familiar with vauxhall parts I'm not sure which is the part number, although I suspect its the second shorter number. Numbers are: P V0090033713 and 017G01 BTW at 39p + vat each they were significantly cheaper than Autofive. Sean Share this post Link to post Share on other sites
2052006 10 Posted June 24, 2007 Sorry to resurrect an old post but thought it might be useful. I've recently bought some rivets from vauxhall which are identical to pt no 8472.20. There are two numbers listed on my invoice, as I'm not familiar with vauxhall parts I'm not sure which is the part number, although I suspect its the second shorter number. Numbers are: P V0090033713 and 017G01 BTW at 39p + vat each they were significantly cheaper than Autofive. Sean I got hold of 12 of these rivets from Vauxhall only a couple of weeks ago. Not sure if I've attached them properly, but they seem to have worked. I also managed to source the anti-rattle clips through Pug. Share this post Link to post Share on other sites
