ross009 0 Posted April 8, 2007 just wondered if anyone had seen or used one o these? would possibly allow the user of bigger injectors without over fuelling at low revs but incresing fuel pressure as boost increases? dont know how good they'd be but could be a cheaper alternative to running a 5th injector/ expensive management http://cgi.ebay.com/ebaymotors/OBX-10-1-FM...sspagenameZWD2V Share this post Link to post Share on other sites
sonofsam 5 Posted April 8, 2007 OBX Racing Sports High Performance Fuel Management Unit (FMU) This FMU allows the car to run normally on a small injector, but can also increase the rail pressure under boost which, in turn, forces more fuel through the same size orifice. The fuel that the FMU adds has a direct relationship to the boost pressure. The Pressure ratio determines how much the fuel pressure is increased per psi of boost pressure. A 12:1 FMU, for example, will increase fuel pressure by 12 psi per psi of boost. It is typically recommended that a 10:1 or 12:1 FMU be used in order to ensure that the A/F mix will not be lean. Sounds like a FSE power boost valve/rising rate regulator.I dont think I would want anything that cost forty quid messing with my fuelling Share this post Link to post Share on other sites
PsychoSimon 0 Posted April 8, 2007 It's a rising rate fuel pressure regulator. They do work, but not brilliantly. I used on on a nova engine i built for instance. 1.4 sri beast. with the rising rate pressure regulator it ran 150bhp, but when i upgraded to a proper ecu and had it mappe with the same boost the car produced 170bhp. you have to remember that the fuel isnt the only thing that needs to be changed the ignition needs sorting too Share this post Link to post Share on other sites
ross009 0 Posted April 8, 2007 yer then i thought u could use renault 5 mangrment for the ignition side as they only require a vacum line and tdc sensor to run which would retard the spark under boost it was just a quick thought i had really as a chaep alternative for ppl doin a 1.6/1.9 turbo conversion in theory i guess it would work maybe just not that great but would get u moving. Share this post Link to post Share on other sites
