5150maxie 0 Posted April 6, 2007 has anyone got a diagram for wiring the second fan to a switch with the relay and fuse? Share this post Link to post Share on other sites
Guest larson Posted April 6, 2007 (edited) has anyone got a diagram for wiring the second fan to a switch with the relay and fuse? The last schema in this topic should help http://forum.205gtidrivers.com/index.php?s...rride&st=10 Do you want manual control over the second fan using on/off switch? Edited April 6, 2007 by larson Share this post Link to post Share on other sites
5150maxie 0 Posted April 6, 2007 The last schema in this topic should helphttp://forum.205gtidrivers.com/index.php?s...rride&st=10 Do you want manual control over the second fan using on/off switch? yes with switch Share this post Link to post Share on other sites
5150maxie 0 Posted April 6, 2007 yes with switch ive got the spot lamp wiring kit which has the relay and fuse but how to i wire it up? Share this post Link to post Share on other sites
