jim205GTI 3 Posted April 5, 2007 Bah........... Went to put my key in the barrel today and it goes in but not fully ... about 50mm off fully engaged .......... so of course can't turn it ......... any ideas how i could solve it? Share this post Link to post Share on other sites
jim205GTI 3 Posted April 6, 2007 Ah ha figured the problem.............. shined a light down the barrel and there's a metal tab down the middle of it..... looks like it fits into the slot on the key. I am guessing thats come down and now won't go back up ( or down) so now the key won't fit in.................. ........ Share this post Link to post Share on other sites
jackherer 543 Posted April 6, 2007 Thats a big problem as you need the key in place to remove the barrel from the steering column so even replacing it will be tricky. You may have to drill it out. Share this post Link to post Share on other sites
jim205GTI 3 Posted April 6, 2007 i thought so i had a quick look through the searches and most of them mention needing the key in the lock to remove the barrel ..................... Share this post Link to post Share on other sites
welshpug 1,666 Posted April 6, 2007 squirt a load of WD40 or suchlike in there then give the key a good wiggle, I guess you mean 5mm not 50mm as the key Isn't much longer than 50mm as a whole! Share this post Link to post Share on other sites
jim205GTI 3 Posted April 6, 2007 Haha yes i meant 5mm........... and now to compound the problem the key has bloody snapped ..... and i can't find the spare ...................... By the looks of it the easiest will be to source an upper steering part and lock set from a 205 being broken Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 6, 2007 Haha yes i meant 5mm........... and now to compound the problem the key has bloody snapped ..... and i can't find the spare ...................... By the looks of it the easiest will be to source an upper steering part and lock set from a 205 being broken If you have a dremel, you could just grind the small lugs from the bottom of the lock that hold it into the upper column surround. If the steering lock is engaged you'll have to do something similar, anyway Share this post Link to post Share on other sites
