DaveK
Renewing Brake Lines
DaveK
Since my brake and fuel lines need to go inside the car ive, hopefully, decided on everything i will need to buy:
Copper pipe, 3/16" 25ft
Brake spanners, unsure of sizes?
Flaring kit, Machine mart jobbie
Braided lines to replace rubber sections, considering just buying the lengths and making self
Union connections, 10mm and 12mm, male and female?
Cable holder things
Gromets to go between bulkhead/bootfloor
Lots of Patience
Anyone able to fill in any blanks?
Cheers, Dave
Edited by DaveK
a hacksaw and a fine file to cut the copper pipe, and a thin cutting disc on an angle grinder to cut the braided hose (neatest way of cutting it)
A hacksaw, Tut tut, Should use a proper pipe cutting tool, But most of the std brake fittings are 11 & 13mm
this job is really easy i pissed it on my car and ive never made them before!
you wont need 25 m of copper unless you are running dual lines to the rear which isnt necessary just get a t piece from peugeot or brakepipe.co.uk
you get a cutter in the machine mart kit which is good so dont use a butchers hacksaw
the neatest way to cut braided hosing is a chisel and hammer and a good thwack
i got my aeroquip hoses from shenpar and it was about 50 quid for a 1900 setup, best kit ive used far better than goodridge !
Edited by 205007
