All Praise The GTI
Coil Swapping
All Praise The GTI
hi there guys need some help if ive tried a search but came up blank so here goes:
ive got an 88 plate f 1.6 gti so got a separte coil on wing and im dropping in a newer engine 1991 with coil on manifold
how do i convert?
help much appreciated
Use the old coil and the old wiring loom with the new engine, ecu, airflow meter etc
If the redundant lugs on the inlet manifold bother you either grind them off or swap for the old engines manifold.
You could fit the new loom and use the inlet mounted coil, or just extend the wiring on the old loom so it reaches the inlet but leaving the wiring intact is the best bet reliability wise.
