g60-r 0 Posted April 1, 2007 been doing some research on tuning my standard 1.9 and thinking about going down the new cam and port and flow the head. i couldn't find a price any where. can anyone on here give me a rough price to have it done and is there any other mods, tweeks that can be done when the head is off. cheers Roo Share this post Link to post Share on other sites
Miles 331 1 Cars Posted April 1, 2007 I'd give Richard Longman a call, they are one of the best for head work and are fairly priced considering you can get a bad job done for the same money, Only down the road too Share this post Link to post Share on other sites
g60-r 0 Posted April 1, 2007 cheers miles, where are they based? see your not a million miles from me? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted April 1, 2007 In Christchurch, Dorset details are found in Yellow pages no web page thou Share this post Link to post Share on other sites
phatgti 0 Posted April 2, 2007 (edited) Longmans number; 01202 486569 Edited April 2, 2007 by phatgti Share this post Link to post Share on other sites
g60-r 0 Posted April 2, 2007 cheers guys, just gave them a ring and found out they do a modified head for £700 plus vat. for that you get your head ported and flowed, fast road cam and a 1mm bigger inlet valve. bit more then i was looking to spend, might be leaving my beast as standard for a while:( Share this post Link to post Share on other sites
DamirGTI 333 Posted April 2, 2007 Hi ! You can try to do this yourself , at least a little bit of porting and 3 angle seats .. http://forum.205gtidrivers.com/index.php?s...59&hl=inlet Cheers Damir Share this post Link to post Share on other sites
Dom9 2 Posted April 3, 2007 Autosprint in Birmingham do some good work and are a lot cheaper! Share this post Link to post Share on other sites
ross009 0 Posted April 3, 2007 Hi ! You can try to do this yourself , at least a little bit of porting and 3 angle seats .. http://forum.205gtidrivers.com/index.php?s...59&hl=inlet Cheers Damir could this work be done on an xu10 head also i mean obviuosly it can but as david from puma says its easier to see what needs to be done on some heads than it is others does the xu10 hae similar port charecteristics as the xu9? as im thinking of using an xu10 head but wasnt sure if it would be worth it as i cant afford hundreds of pounds of head work but the combo of the bigger valves and some light porting by myself would surely be quite beneficial? Share this post Link to post Share on other sites
TEKNOPUG 3 Posted April 3, 2007 could this work be done on an xu10 head also i mean obviuosly it can but as david from puma says its easier to see what needs to be done on some heads than it is others does the xu10 hae similar port charecteristics as the xu9? as im thinking of using an xu10 head but wasnt sure if it would be worth it as i cant afford hundreds of pounds of head work but the combo of the bigger valves and some light porting by myself would surely be quite beneficial? Run a search - loads of info on this Share this post Link to post Share on other sites
pdd144c 0 Posted April 3, 2007 SMD or Longmans are the people to speak to. Share this post Link to post Share on other sites
