5150maxie 0 Posted March 31, 2007 my front washer motor is working but not much pressure coming out of the jets?when i test it on the battery its more powerful?ive already cleaned the earth block behind head light the dash stalk works ok?could it be earth still? Share this post Link to post Share on other sites
PsychoSimon 0 Posted March 31, 2007 it probably is, try running a new earth for it just to be sure Share this post Link to post Share on other sites
Sandy 191 Posted March 31, 2007 Or a kink in the pipe perhaps? Share this post Link to post Share on other sites
Super Josh 4 Posted March 31, 2007 It will be the corrosion on the connector that plugs into the washer motor. Clean it up and put some vaseline on it to stop it corroding again too soon. Josh Share this post Link to post Share on other sites
5150maxie 0 Posted March 31, 2007 nice one thanks i will look tomorrow.i bet its earth you know what peugeots are like Share this post Link to post Share on other sites
Andrwn8304 0 Posted March 31, 2007 Sounds more like a blockage in the pipe, it normally happens on older as the water/screen wash gels up and blocks the jets. A quick fix is to blast air back down from the jets to washer bottle. Share this post Link to post Share on other sites
pj838 0 Posted March 31, 2007 Its probably worth replacing the jets anyway if they are old? I got some from Neat Autos about £1 each, much better. Share this post Link to post Share on other sites
5150maxie 0 Posted March 31, 2007 Its probably worth replacing the jets anyway if they are old? I got some from Neat Autos about £1 each, much better. every thing is new,my cars been stud for a bit.im going to check the wiring later, the motor works but not enough power to blast waster to the window, Share this post Link to post Share on other sites
5150maxie 0 Posted April 1, 2007 ive sorted it i removed the head light and cleaned the earth points with a bit of emery cloth. Share this post Link to post Share on other sites
