5150maxie
Washer Jets
5150maxie
my front washer motor is working but not much pressure coming out of the jets?when i test it on the battery its more powerful?ive already cleaned the earth block behind head light the dash stalk works ok?could it be earth still?
PsychoSimon
it probably is, try running a new earth for it just to be sure
Sandy
Or a kink in the pipe perhaps?
Super Josh
It will be the corrosion on the connector that plugs into the washer motor. Clean it up and put some vaseline on it to stop it corroding again too soon. :blink:
Josh
5150maxie
nice one thanks i will look tomorrow.i bet its earth you know what peugeots are like :blink:
Andrwn8304
Sounds more like a blockage in the pipe, it normally happens on older as the water/screen wash gels up and blocks the jets. A quick fix is to blast air back down from the jets to washer bottle.
pj838
Its probably worth replacing the jets anyway if they are old? I got some from Neat Autos about £1 each, much better.
5150maxie
every thing is new,my cars been stud for a bit.im going to check the wiring later, :) the motor works but not enough power to blast waster to the window,
5150maxie
ive sorted it i removed the head light and cleaned the earth points with a bit of emery cloth. :)
