Guest RsDarren
309 Gti Rear Axle
Guest RsDarren
The owner before me has changed the rear axle on my Pug 205, it now houses a 309 Gti rear axle and brake set up.
Were there two shapes to the 309? As Im trying to order some brake pads and discs for them and wondered if there was any different shapes or models? I dont have the reg of the 309 that my axle came off?
Darren
sherly
Same brake setup for 205 and 309 rear discs/pads as far as I'm aware. Only difference between the beams - wider track and stiffer (thicker) torsion and anti roll bars.
Mart :)
Edited by sherly
Guest Ade C
Yep, they're the same, or at least they were on my now deceased 1990 309, the rear beam on which was swapped onto my 1986 1.9 205.
Ade
