inferno 1 Posted March 27, 2007 any down side to mounting the mc upside down? ie pipes come out the bottom, and the reservoir fill tube does a ubend to the mc? the reservoirs will still be around 6inches higher than the mc, so im assuming the only issue could affect initial bleeding of the mc? Share this post Link to post Share on other sites
axnutty 10 Posted March 27, 2007 Id have thought it would be OK as its a sealed system isnt it ??? Given as you say the reservoir would be mounted the right way up - and as you already mention the bleeding problem. Never heard of anyone doing it though :S Share this post Link to post Share on other sites
TKH 0 Posted March 27, 2007 What would happen if you do get air in the MC? Normally it makes its way out to the reservoir as the system is open when the pedal is not pressed. Share this post Link to post Share on other sites
