Ryan
Trim Clips Kit
Ryan
I remember somebody saying that a complete kit of new side trim clips was available from Pug for about £20. I did a search and came up with part number 6994 44 (here), but I rang the dealer and they said that number doesn't come up with anything. :)
6994 44 doesn't show up on my parts CD either (the 2003 version). I did find 6999 30 which looks like a collection of clips, but I get the impression that that's a smaller kit with parts for one door, or possibly even one trim peice only. The dealer didn't know either.
Does anyone know if 6999 30 is really the one I want, or is there something else?
tom_m
last time i got clips from the dealer the parts lady said the smaller kit was not available any more so she got me the full bumper kit instead. i'll dig out the PN tonight if no-one else beats me to it
de Noir
Tin trim clips aren't available from Peugeot any more.
ORB
whats the damage on one of them kit thingamybobs?
de Noir
I just bought one of the 6994.44 kits.
Pictures should clear things up, it includes most of the clips needed for the whole car maybe?
Oh no!! :D
This box could have solved many problems... I have been told these tin clips aren't available any more. :D
Hilgie
don't believe what you've been told...Peugeot parts dept of most main dealers don't know s*it
Ah, excellent, i wasn't aware they were available!! (if they can be got) How much pleasey??
Grim.Badger
I tried 6 different Peugeot dealers, all different companies, for the tin rivetts and they all said they were unobtainable :D The tin clips are easy enough to get though :D
Edit: I hope it comes with lots of bits because its £25.83 :D
Edited by Grim.Badger
Wooo, that's a bit steep!! mind you i suppose we should expect it to be an arm and a leg!!
Hilgie
The rivets can also be obtained from a Vauxhall dealer. The same rivets were used on the Calibra.
Grim.Badger
Great! You haven't got a part number handy have you?
Hilgie
No, sorry. Just have to ask there I guess....
de Noir
I'm not believeing the hype either...
Tried to place direct order, Peugeot spare parts told me no more clips. :o
Then I removed trim rivets from everywhere and opted for 3M mounting tape instead...
Lucky me. :D
Edited by MH_
which clips do you want?
B1ack_Mi16
At least the plastic ones that go over the rivets and fasten the black plastic trim to the doors etc. are avaliable separately from peugeot on another partnumber.
these buggers -_-
and
cybernck
sorry for bumping this topic up, but kris, your pics are missing.
so tin clips are 6994 Q3 and black slide clips are 6996 24.
what's the part number for white plastic "push through" clips?
what about side trim itself and trim inserts?
mossy
Vauxhall pt no for metal rivets is
90033713
Hope this helps
Al
I guess you mean the ones with barbs that simply push through the wing/rear arch, which IIRC is this one 6992 98 CRANK CLIP 6X21
the other type has a fibre washer than a spring type washer that pushes onto a plain shank.
part numbers for this type are 8565 14 (not sure what to call it, "pin"? the white bit!) which you have to use with 8565 15 SEAL WASHER DIAM 5 and 6992 98 CRANK CLIP 6X21
all numbers on this page - http://www.stuartmcguire.co.uk/pug/GB/205F/8/85E10A.HTM
and this one - http://www.stuartmcguire.co.uk/pug/GB/205F/7/78E10A.HTM
