Casanova 0 Posted March 25, 2007 I am looking for a 266mm setup for my 205 and found a website selling some 266mm grooved and drilled discs. The information given is as follows: Diameter: 266mm Bore: 66mm Height: 27mm Thickness: 20.5mm Now diameter and thickness are pretty obvious, and I'm fairly sure the height is the thickness at the mounting point (i.e. including any offset). Correct me if I'm wrong here. But I'm not sure what the bore is - is it the diameter of the hole in the middle where it mounts on the hub? In which case, what is the bore of a 205 XS? (in case anyone knows off the top of their head, to avoid me going out and taking a wheel off) Thanks § Share this post Link to post Share on other sites
Casanova 0 Posted March 25, 2007 Don't know if it helps, but the listed applications are: Citroen Xsara 1.4, 1.6, D, 1.9TDi estate, 1.6, 1.8 coupe, 1.8 16v hatch Peuegot 206 2.0 GTi, 2.0 HDi - 1999 - 2006 Peugeot 306 2.0 Xsi, Cabriolet, S16 - 1994 to 1997 Peugeot 405 1.4, 1.6, 1.8, 1.9, 2.0, D & TD - 1988 to 1997 § Share this post Link to post Share on other sites
