matty_gti
How Many Revs Are You Doing?
matty_gti
hi all, maybe silly but ive just fitted a new tacho with shift-light and im a little iffed about it reading correctly....i cant really test it against the original tacho because that isnt working at eth moment. So....
In your 1.6 Gti's people how many revs are you doing at 52/53 MPH in 5th gear!?!....I just want to know as my car at the moment has 17's on it.
Thanks.
Can't be certain as I've not had a 1.6 box fited for a while & its a while since I've driven a car with one fitted but working it out mathmatically I get somewhere about 2800rpm.
The standard 1.6 GTi gearbox does 18.9 mph / 1k rpm in fifth.
Graham.
matty_gti
- Is that somthing you have just worked out or somthing you just know?, do you have any calculations to work out things like that?.
With the above in mind if im correct, it works out at 18.9 mph x 3 (k RPM) = 56mph in fifth, where i on the other hand am doing 51mph...could this be down to the size of wheel?
Thanks.
Edited by matty_gti
