jonand 0 Posted March 22, 2007 Desparately need an ignition base map using TPS v revs (alpha n) if anyone has one. S16 in standard spec but with R1 bike carbs and wasted spark coil pack - used for autograss racing only. I believe that 12* at tick over and 36* from 3000rpm upwards at full load is about right, but not sure of the spread through the partial throttle area. I'm using MSnS Extra v3, but I assume that any make would provide suitable data - albeit that I would have to manually enter into the tuning software. Thanks Jon PS I have searched, and got loads of good info - but not what I'm looking for. Share this post Link to post Share on other sites
Sandy 191 Posted March 22, 2007 36 degrees at full throttle is probably too much, without checking it in the rollers I wouldn't exceed 28-30 degrees on a 16v. Share this post Link to post Share on other sites
jonand 0 Posted March 22, 2007 36 degrees at full throttle is probably too much, without checking it in the rollers I wouldn't exceed 28-30 degrees on a 16v. Ok thanks for the warning. Share this post Link to post Share on other sites
petert 586 Posted March 23, 2007 I was posting some data this morning when my laptop died. However, I've posted it on here before for someone with MSII from memory. I suggest a search. Share this post Link to post Share on other sites
jonand 0 Posted March 23, 2007 I was posting some data this morning when my laptop died. However, I've posted it on here before for someone with MSII from memory. I suggest a search. Thanks Peter - have searched but will try again. Regards Jon Share this post Link to post Share on other sites
Jakob 1 Posted March 24, 2007 My base map ignition timing configurator - mostly for forced induction, but maybe you can find something useful. http://www.powerpage.dk/tuning_ignition-fi...rtsmap_v106.xls Choose english as language. /Jakob Share this post Link to post Share on other sites
petert 586 Posted March 24, 2007 Have a look at this thread: http://forum.205gtidrivers.com/index.php?showtopic=55730 Share this post Link to post Share on other sites
jonand 0 Posted March 27, 2007 Thanks Guys - still looking at numbers. Think I am getting the idea Share this post Link to post Share on other sites
