eob
Zx Hubs
eob
Haven't had time to climb under it, yet, but my uncle has a junk ZX behind his house, just wondering if it has identical hubs to the 306, ie...
Are they hollow cast?
Are they the right dimensions?
Sandy
Not on the lower power models, but the most of the XU's. Worth mentioning that i've just noticed that the strut is less inclined laterally on the 306/ZX/Xsara uprights. This will mean less negative camber on the 205.
jonnie205
Are you sure about the camber thing sandy? pug now supply you the 306 hub when you go in asking for a 205 one
eob
I did check on the GSF website and it's the same part number for all the bearings on the 306/Xsara/ZX/205 hubs EXCEPT for the 1.9 GTi. I presume you use 205 1.9 driveshafts with 306/ZX/Xsara hubs, correct?
jonnie205
yep 1.9 shafts
