Jrod
Bolt Through Spacers
Jrod
Saw these on ebay
Going very cheap so I am considering buying them, only problem is the threads have been stripped.
I wondered if it would be possible/safe to bolt the wheels on though the hole deisnged to hold the sapcer to the hub and not use the holes designed to bolt the wheels onto the spacers?
johnnyboy666
the holes to bolt the spacer to the hubs have recesses for the the bolt heads so the bolts wont be touching much if they go through the wheel first, as to whether that'd make a lot of difference im not sure, i would've thought it would be like using those wobble nuts on 98x4 pcd cars with 100x4 wheels
you could try and fashion a washer type thing that could sit in the recess (possibly using some old wheel bolts) and that might be a bit better? or just drill a fresh set of holes?
Rippthrough
Better off cleaning the damaged holes up for the bolts to go through.
johnnyboy666
yes that seems much more plausable than my ideas hehe
sonofsam
I personally wouldn't bother, cheap usually equals ball ache in the future :D
If the threads been completely stripped then it will have to be re-cut oversized, so wont you have
problems finding correct sized bolts? and do you really want to risk a pair of spacers that have been abused?! More hassle than it's really worth isnt it?
28CRAIG
You could drill the hole out and use a helicoil insert will be alot stronger than the original thread.
drill the holes out to 14mm and get longer bolts.
Jrod
I can't be bothered with that hassle, just though yo might be able to bole them on through the other holes! :D
