Wicker man
Whats This?
Wicker man
i aint got a clue
cooling fan resistor
Wicker man
oooooooooooooook riiiiiiiiiiiiight so you no my next question lmao
whats a cooling fan resistor do?
thank you btw
Edited by Wicker man
hengti
i thought it was camera shake :)
the first pin on the rad switch activated by heated coolant sends current to the fan via that resistor, hence the lower speed, when the second one comes on it goes straight to the fan/s.
Wicker man
arha
GLPoomobile
And make sure you put it back somewhere where it won't touch other wires as it will melt em.
If you are giong to cable tie it back in place, don't put the tie around the metal body of the resister, as again it will melt it (unless you use metal tie wraps)
Wicker man
hmm its kind of jammed in the corner with wires all around it
was like that when i found it honest boss
