sport1901966
Piston Rings Replacement
sport1901966
As above, loosing a fair bit of compression and I have a strong feeling the rings are shot.
Any ideas on cost to replace, ideally looking for placed around Bromley/Wimbledon.
Thanks guys
brianthemagical
from pug, 83mm bore, set of three, £25+vat, per cylinder, with no instructions. they do come in boxes wrapped in anti-corosion paper, which is nice.
it is possible to get diffrnt desidns, not sure who form but one of my engines had different rings.
hope that helps.
M@tt
i'm sure you can get the parts a bit cheaper cheaper than than by not going to pug iirc when i rebuilt my mi16 i was quoted £75inc vat for OE quality parts by the people that did my engine work. I'm sure Mattsav or Miles will be able to tell the brands you want to be aiming for, and probably be able to supply them cheaper as they are in the trade.
Are you planning on doing the work yourself? or getting someone to do it for you? you'll also want to factor into the cost getting your liners honed so that they seal really well with the new rings. costs about £20+vat but you'd proabably have to take the liners out as well to get a machine shop to do it and that's mean new liner seals as well. or you could buy one of those drill attachedmaents and do it DIY
just some food for thought
Edited by M@tt
Andrwn8304
I would replace the liners aswell as you normally get a ridge on the liners/bores which would snap any new Ring on its compression stroke -
AutoFive stocks these
EM114 Piston ring set £62.95
EM116 Piston/ring/liner kit 1.6 £279.00
EM116B Piston and ring set 1.9 £189.00
EM116C Piston/ring/liner kit 1.9 £279.00
Edited by Andrwn8304
A hone normally does the trick to suit the Ring's, Ring's around £90.00 a set and honing the liner's if able to £35.00, Liner seals £12.51 then gasket's & Headbolt's on top of that and while the head's off the stem seals may aswell be done at the same time
no need to get new liner's etc
sport1901966
Interesting thoughts there cheers for the detailed responses!
It'll probably be done by a garage. I'm actually asking for myself and my brother, both of us own 1.9 gti's with the same issue although I'm pretty certainly going down the MI16 route so this is more for his benefit.
Thanks again, you are certainly a helpful lot!
