swordfish210 20 Posted March 17, 2007 Does anyone know what driveshafts i would have to use if i were to swap my XT suspension set up for a 1.9 GTI front end. Plus anymore information about this swap would be greatly appriciated. Thanks Share this post Link to post Share on other sites
jackherer 543 Posted March 17, 2007 use the original (XT) driveshafts and hubs with the GTI wishbones and struts. Share this post Link to post Share on other sites
swordfish210 20 Posted March 17, 2007 ok thanks, also what brakes would i use, considering i'm using the XT hubs, can GTI ones be adapted to fit Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 17, 2007 1.9 brakes will fit straight on or as used on the STDT, 1.9 discs & 1.6 GTi Bendix calipers. Graham. Share this post Link to post Share on other sites
swordfish210 20 Posted March 18, 2007 OK, i'v got a subframe now, it came with the ARB, drop links, and a steering rack, i also have some struts and springs from a 1.9 GTI. The guy i bought the subframe from also gave me the discs that were fitted to it (1.9 GTI vented discs) so am i right in saying thet all i need now is some 1.6 GTI bendix calipers and i will have everything i need to do the swap. Anymore info will be greatly appriciated. Thanks Share this post Link to post Share on other sites
swordfish210 20 Posted March 18, 2007 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...p;rd=1&rd=1 these are apparently from a E Reg 1.6 GTI, so i assume they would fit, yes? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 19, 2007 i need now is some 1.6 GTI bendix calipers and i will have everything i need to do the swap. Either that or some 1.9 GTi calipwers & mounting bolts. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...p;rd=1&rd=1 these are apparently from a E Reg 1.6 GTI, so i assume they would fit, yes? Hard to say from a picture but the pad guide doesn't look wide enough for the vented discs with the piston pushed that far back imo. Might just be a bad picture though. Get the seller to check the bleed nipples are Ok though before/ if you bid, if they shear off on him then at least you've saved buying them for it to happen to you. Graham. Share this post Link to post Share on other sites
