2052006 10 Posted March 16, 2007 Tried a search but couldn't find anything. How do you remove the washer jets from the bonnet?? Share this post Link to post Share on other sites
fencer 0 Posted March 16, 2007 i think u can just push them out, the one I have is with only 1 hole so if u have the two hole version it might be different but to remove them I only had to push them out. Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted March 16, 2007 You will see two plastic flaps one either side under the bonnet, pinch them together and push and they will come out. Share this post Link to post Share on other sites
2052006 10 Posted March 16, 2007 i think u can just push them out, the one I have is with only 1 hole so if u have the two hole version it might be different but to remove them I only had to push them out. done - thanks! Share this post Link to post Share on other sites
Paintguy 0 Posted March 16, 2007 I find a deep 10mm socket does the trick nicely. Push it onto the back of the jet and it presses all 4 flaps at the same time Share this post Link to post Share on other sites
