Alan_M
Fitting Bucket Seat
Alan_M
Before I disappear to the 'Ring again in April, I'd like to mount my bucket seat on new mounts lowering the seating position.
I've got the general gist of it, and have been practising welding on a MIG. Not used MIG before, only Oxy-Acetylene.
Got a 1m length of oblong steel tubing, and big washers and bolts etc today, so would like to have a go tomorrow.
Just want to clear one thing up, when welding in the new bars do you inset the new bars into the sills/exhaust tunnel (make holes big enough for the bars in tunnel and sills, and pus bar into tunnel/sill) or weld on top of the metal? If you get what I mean?
Also, what height hve people welded theirs?
Alan
dommorton
Welded my bars to the metal and not through it. They are very strong and not likely to come off in a hurry.
Height depends on the seats and mounts you're using. Just play about with mock up's until you're comfortable.
bren_1.3
not a common practice to route the bars through the metal, rather over the top. but in rallying circles running the bars through the metal can strengthen up the shell further. (i assume you car is caged)
Alan_M
Thanks,
Another question, is there anything wrong with welding the square tubing to the floor, then bolting through tubing and floor?
dommorton
You really can't do this job a wrong way. If the welds are strong and the seat mounted where you want it, then it'll be fine.
Mr_E
Every car I have built, i have first welded a 2mm thick plate onto the inner sill and the tunnel where I want to mount the rails. The plate i use is an inch or so larger than the tube I are use for my seat rails. I then weld the seat rail tube to these plates.
I have never put holes through the sills or tunnels and welded them that way, i cant see that being as strong.
