david932 0 Posted March 14, 2007 of i was to run an s16 front brake setup and a 1.9gti rear what master cylinder would i need. i currently have a 1.6gti master cylinder thanks Share this post Link to post Share on other sites
Ahl 4 Posted March 14, 2007 The s16 calipers run 54mm pistons, compared to 48mm 205 gti pistons. Some people run them (and the 54mm 307 setup) on the standard M/C and have no problems, though the pedal will be a little longer. Other folks prefer a larger master cylinder to shorten the pedal stroke. I think the favoured one is a 1.8 406 M/C, but you are best to do a search to find this. Theres no reason why you couldn't put it all together as is, and fit a larger M/C later if you feel the need. Share this post Link to post Share on other sites
welshpug 1,682 Posted March 14, 2007 405 uses these calipers with a 22.2mm M/C on the Mi16, but the ZX and 306 use a 23.8mm unit! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 14, 2007 405 uses these calipers with a 22.2mm M/C on the Mi16, but the ZX and 306 use a 23.8mm unit! 306 S16's use a 22.2mm mc just like the 405. My ZX Haynes doesn't state what size mc they have fitted to any model. Graham. Share this post Link to post Share on other sites
welshpug 1,682 Posted March 14, 2007 oh! just went off what Euro car parts told me, I'll do my best to confirm what it has asap Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 14, 2007 oh! just went off what Euro car parts told me, I'll do my best to confirm what it has asap I checked before I replied, ECP lists both a 222mm & a 23.8 mc for the S16 engined 306; Manufacturer:Citroen Year:1994 Model:ZX Hatchback 2.0i 16v : XU10J4D Search: BRAKE MASTER CYLINDER Manufacturer Image Part No Description Stock *Price ATE n/a 132735050 MASTER CYLINDER 306 +ABS 22.2mm-B. 22.2mm Diam £56.22 METELLI n/a 132735051 MASTER CYLINDER 306 +ABS 22.2mm-BPEUGEOT 306 ABS 22.2mm Diam £35.66 BOSCH n/a 132735220 B.M CYL 306 2.0 16v S16 . 23.8mm Diam Graham. Share this post Link to post Share on other sites
welshpug 1,682 Posted May 4, 2007 just to update, I was working on my ZX earlier and it has a 23mm M/C and the 405Mi16/306S16 calipers (54mm pistons) Share this post Link to post Share on other sites
