Rik
Gudjeon Pins
Rik
So i was thinking of lightening + balancing my Mi16 Pistons + Rods for my track car.
So first i enquired how much each pin from Peugeot is...... £32.18 for 1 pin!!!!!
Can they be refitted after removal? if so what are the possible disadvantages to fitting new?
Rik
If there the Mi16 pistons with the floating pin then you have no problems with re-using them, even the press fit 8v ones are fine to re-use
I'd be shocked if you couldn't re-use an Mi gudgeon pin, they can be pressed out by hand once the circlip is removed.
ALEX
Little end bearing gets less ware than the big end anyway so should be fine to reuse.
Get them checked if your concerned though.
Rik
any one got the minumin material specs for them?
Rik
