Rik 0 Posted March 14, 2007 So i was thinking of lightening + balancing my Mi16 Pistons + Rods for my track car. So first i enquired how much each pin from Peugeot is...... £32.18 for 1 pin!!!!! Can they be refitted after removal? if so what are the possible disadvantages to fitting new? Rik Share this post Link to post Share on other sites
Miles 331 1 Cars Posted March 14, 2007 If there the Mi16 pistons with the floating pin then you have no problems with re-using them, even the press fit 8v ones are fine to re-use Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 14, 2007 I'd be shocked if you couldn't re-use an Mi gudgeon pin, they can be pressed out by hand once the circlip is removed. Graham. Share this post Link to post Share on other sites
ALEX 98 1 Cars Posted March 15, 2007 Little end bearing gets less ware than the big end anyway so should be fine to reuse. Get them checked if your concerned though. Share this post Link to post Share on other sites
Rik 0 Posted March 15, 2007 any one got the minumin material specs for them? Rik Share this post Link to post Share on other sites
