whizzer71 0 Posted March 11, 2007 Hi all,just finished wiring up etc,looking for good base map for engine with standard inlet manifold,have base map for throttle boddies as supplied by emerald but car runs like a bag of P** any help would be appreciated Cheers Share this post Link to post Share on other sites
16v205 9 Posted March 11, 2007 ive got a mi16 base map with the standard inlet manifold if thats any use? Id offer you my gti-6 map but it wont be any use. Rich Share this post Link to post Share on other sites
whizzer71 0 Posted March 11, 2007 (edited) ive got a mi16 base map with the standard inlet manifold if thats any use? Id offer you my gti-6 map but it wont be any use. Rich Were you running 4 independent coils or a single pack ? I believe the map would be different for the two set ups ?....Unless Im completely wrong ????????? But otherwise I would be very gratefull If you could mail me a copy. Cheers Tris Edited March 11, 2007 by whizzer71 Share this post Link to post Share on other sites
16v205 9 Posted March 12, 2007 Im running a coil pack off a 406 which fires wasted spark, I enquired about running the 4 gti-6 coils and it cant be done without emerald adding a another few ingintion drivers. If youve wired up all 4 coils to your emerald as it is on a gti-6 it wont run really, and you'll also burn out the ign amps. Whats your email address? Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted March 12, 2007 Im running a coil pack off a 406 which fires wasted spark, I enquired about running the 4 gti-6 coils and it cant be done without emerald adding a another few ingintion drivers. If youve wired up all 4 coils to your emerald as it is on a gti-6 it wont run really, and you'll also burn out the ign amps. Whats your email address? i have done this on my gti6 running emereald but havent tried the engine yet. i take it i will need to use a coil pack instead of the 4 seperate coils on the six engine ? bugger oh well least i found out now not later and had a proper head scratching moment when it wont fire up. Share this post Link to post Share on other sites
Malachy 0 Posted March 12, 2007 Were you running 4 independent coils or a single pack ? I believe the map would be different for the two set ups ?....Unless Im completely wrong ?????????But otherwise I would be very gratefull If you could mail me a copy. Cheers Tris the map wont be any different just the configuration, it will still have x spark angle at y rpm and z load. Share this post Link to post Share on other sites
whizzer71 0 Posted March 12, 2007 Email as requested silverainbow@btinternet.com Cheers Share this post Link to post Share on other sites
