Richie-Van-GTi 80 2 Cars Posted March 8, 2007 Can someone explain in laymans terms how these are calculated please. I feel its something I should know but dont Id be interested in working my own spec out (see sig) but it would be more useful when reading posts TBH. Share this post Link to post Share on other sites
welshpug 1,712 Posted March 8, 2007 compression ratio is the difference between total cylinder capacity when at BDC and TDC (bottom and Top dead centre) petrol engiones being spark ignition dont need that high a compression ratio, Diesel on the other hand is a compression ignition hence the higher figures involved (boost and Compression) Share this post Link to post Share on other sites
welshpug 1,712 Posted March 8, 2007 so going on that theory a 1905 Mi16 running 10.4-1 has a total difference of 1905cc to 183 ish cc. Share this post Link to post Share on other sites
smckeown 2 Posted March 9, 2007 dave's good for some things.. http://www.pumaracing.co.uk/CAPACITY.htm Share this post Link to post Share on other sites
petert 630 Posted March 9, 2007 so going on that theory a 1905 Mi16 running 10.4-1 has a total difference of 1905cc to 183 ish cc. Not quite. The formula is CR=(Vs+Vc)/Vc eg. for an Mi16 Vs = 1905/4 = 427cc (swept volume of one cylinder) Vc = 45.4cc (volume in chamber, head gasket etc.) CR = (427+45.4)/45.4 = 10.4 Share this post Link to post Share on other sites
Richie-Van-GTi 80 2 Cars Posted March 9, 2007 haha, now I understand, always read it as 11 to 1 in a ratio kind of way when infact it is 11 point 1 like a decimal number. Makes much more sense. So assuming I find out the swept volume of my bottom end and the approximate clearnance volume of the 1.9 head plus a fraction for the bit in the top of the cylinder that isnt swept then I could find out a fairly accurate CR for the engine thanks to all that replied, Ive learnt something new Share this post Link to post Share on other sites
Normski 1 Posted March 9, 2007 haha, now I understand, always read it as 11 to 1 in a ratio kind of way when infact it is 11 point 1 like a decimal number. Makes much more sense. No, it is a ratio (compression ratio). The example above of the Mi16, it has a compression ratio of 10.4 to 1 (10.4:1). Share this post Link to post Share on other sites
Faz85 0 Posted March 9, 2007 (edited) Not quite. The formula is CR=(Vs+Vc)/Vc eg. for an Mi16 Vs = 1905/4 = 427cc (swept volume of one cylinder) Vc = 45.4cc (volume in chamber, head gasket etc.) CR = (427+45.4)/45.4 = 10.4 Your maths is slightly wrong there peter, 1905/4= 476.25cc and the Clearance Volume, Vc for the Mi is actually 50.7cc That gives you CR=(476.25+50.7)/50.7 = 10.4 So assuming I find out the swept volume of my bottom end and the approximate clearnance volume of the 1.9 head plus a fraction for the bit in the top of the cylinder that isnt swept then I could find out a fairly accurate CR for the engine Yep, and the exact clearance volume for the 1.9 head (assuming its an 8v) is 55.38cc I dont know what the swept volume is for the 2.0 bottom end you have, but if you get it from the joke book you can bung it in the above equation along with the clearance volume i've just calculated for you, and get the EXACT CR for your engine Faz Edited March 9, 2007 by Faz85 Share this post Link to post Share on other sites
petert 630 Posted March 10, 2007 Your maths is slightly wrong there peter, 1905/4= 476.25cc You're right! It's amazing how much clearer things are in the morning. Deamon drink. Share this post Link to post Share on other sites
Richie-Van-GTi 80 2 Cars Posted March 10, 2007 Thanks for that Faz, I work it out to be 498.5 swept volume and using 56 for the Vc I get a CR of 9.9.1. Share this post Link to post Share on other sites
Sam 4 Posted March 10, 2007 http://www.csgnetwork.com/compcalc.html Handy calculator. Share this post Link to post Share on other sites
christopher 5 1 Cars Posted March 13, 2007 Here are the words on the topic by Guy Croft http://guy-croft.com/viewtopic.php?t=164 Share this post Link to post Share on other sites
petert 630 Posted March 14, 2007 (edited) This is my favourite: http://www.empirenet.com/pkelley2/DynamicCR.html read it, digest it, then download the calculator. You can use it for static or dynamic CR. Edited March 14, 2007 by petert Share this post Link to post Share on other sites
