GazRallye 0 Posted March 6, 2007 I fitted a new drive shaft on the n/s about a month ago, it was all well for a a few miles then a knocking sound started, similar but different from the one when the old one was on and sounds like a driveshaft problem ie, wobbling sound when power is applied round left hand bends and it definately feels/sounds like its coming from the same side. Also it seems to be leaking a bit of gearbox oil. Share this post Link to post Share on other sites
GazRallye 0 Posted March 6, 2007 yeah its fine, i changed the driveshaft on my ax loads of times and never had a problem, the wheel bearing doesn't have any play in it either is there an oil seal that might not be seated correctly where the shaft meets the box? Share this post Link to post Share on other sites
TKH 0 Posted March 6, 2007 (edited) I dont know if this is a problem on the 205, but on the 106, Saxo and AX its acutely possible to get drive shafts to hit the inner wing of the cars with some suspension setups. If this is happening it will kill a even new drive shaft in no time at all. Worth a look at least I guess. Edited March 6, 2007 by TKH Share this post Link to post Share on other sites
GazRallye 0 Posted March 6, 2007 (edited) you mean if its slammed on its belly? my AX used to eat them for fun because it was lowered not so extreme that it touched the inner wing tho, my 205 is completely standard ride height Edited March 6, 2007 by GazRallye Share this post Link to post Share on other sites
