skinner2k3 3 Posted March 6, 2007 The choke light on my 1.9 8v XU wont go off. Even once the engine is fully up to temp. Which sensor or wire or whatever should I check? Also where is the oil temp sensor for the guage? Thanks Share this post Link to post Share on other sites
Craigb 2 Posted March 6, 2007 which is the choke light ? Share this post Link to post Share on other sites
welshpug 1,666 Posted March 6, 2007 they dont have one?? temp sensor for oil gauge is on the back of the sump. Share this post Link to post Share on other sites
skinner2k3 3 Posted March 6, 2007 Ah, ok...I am being an arse I will have another look tonight. There is deffinately a light staying on and I was sure it was a choke light. I have tried to find a image on the net of the intruments so I could describe which it was but as I couldnt find one with the lights on I cant remember which it is Share this post Link to post Share on other sites
Ren 0 Posted March 6, 2007 Found this on the main site if it's any use http://www.205gtidrivers.com/articles/m-instrumentpanel.html Ren Share this post Link to post Share on other sites
skinner2k3 3 Posted March 6, 2007 Found this on the main site if it's any use http://www.205gtidrivers.com/articles/m-instrumentpanel.html Ren Nice one Ren, Its that one, third from the bottom on that article. Should only be for carb'd models. Wonder why its lighting on mine? Share this post Link to post Share on other sites
Ryan 99 Posted March 6, 2007 There should normally be a spare yellow spade connector loose under the steering wheel (wire number 75). Sounds like somebody thought it was supposed to be plugged into something - probably the nearby earth block. Just unplug it and it'll be fine. Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted March 6, 2007 or simply pull the bulb out Share this post Link to post Share on other sites
skinner2k3 3 Posted March 7, 2007 Ah ha, cheers Ryan. Will have a look tonight. If not, bulbs coming out! Share this post Link to post Share on other sites
