sorr 0 Posted March 4, 2007 (edited) I have one remaing issue with my Mi conversion and am looking for some help. The issue is that 2 times out of 3 the revs seem to hang at 2K then gradually fall back down to idle. I have tested every component and the only things not swapped out are the throttle body, TPS and ECU, it is a 3 row by the way. The TPS does give the correct resistances when tested, thanks to Higgy for helping , but could it be failing when voltage is applied so causing the high idle? Or could it possibly be a worn throttle body? This is where I say again it only happens about 2 times out of 3. Anthony has kindly offered to lend me another throttlebody but I would rather I had a possible cause for the issue rather than guessing. Thanks in advance. Edited March 4, 2007 by sorr Share this post Link to post Share on other sites
Green Machine 3 Posted March 4, 2007 It sounds like a air leak to me. check all pipes for cracks/splits, make sure all clips are tight. also make sure the inlet manifold is sealed properly and that the injectors are seated. Share this post Link to post Share on other sites
sorr 0 Posted March 5, 2007 Thanks for the reply. Where did I put that tube of RTV? Share this post Link to post Share on other sites
