miamigtimark
Sunroof Broken!
miamigtimark
Hi all,
My first post and im on the beg already!! :(
Basically the sliding sunroof on the car will not open. Its the full length glass one with the turning handle marked "Britax". The handle turns with no resistance but does nothing. How much work is involved and what do i need to fix this???
Cheers!
miamistu
Sounds like your vacuum isn't working properly. Do your brakes work ok?
miamigtimark
Brakes appear to be fine. TBH ive only driven the car once as it needs a clutch. Ive heard about the vacum system when the engines running but i only thought this prevented leaks and had little to do with the opening/closing operation of the roof. how does the opening mechanisem work (eg tooth/chain belt etc)
Cheers.
Super Josh
The Britax one is a dealer fit option and doesn't rely on the vacuum.
Josh
Edited by Super Josh
miamigtimark
Has anyone had to fix one of these. How did you do it??
miamigtimark
Have taken the inner handle apart and removed the wind deflector also . have found that the handle should operate 2(?) cables that are threaded and move on a worm type principal to operate the roof back and forth. These have snapped. Can i get hold of these as a seperate part???
