inferno 1 Posted March 3, 2007 I fitted a bias pedal box, but the reservoirs mount directly on the MC and in the turbo's way. i want the reservoirs to sit up in the scuttle part behind the bulkhead, opposite sides to where the vacuum tank is for the sunroof. am i likely to have any issues with operation/bleeding by doing this? would normal brake pipe be good enough to move them or should i find a thicker ID pipe? Does it matter so long as the tanks are higher than the MC's? Share this post Link to post Share on other sites
Normski 1 Posted March 3, 2007 As you say, as long as the reservoir is higher than the M/C you could put it anywhere you liked. The pipe doesnt need to be anything special, there's no pressure acting on it from the brake system. Share this post Link to post Share on other sites
