Guest twinbridge01 Posted March 2, 2007 I have recently carried out an Mi16 conversion fitting a 1991 Mi16 engine and wiring loom into my 1991 205 1.9. One of many teething troubles I have is that the engine wont idle below about 1800rpm, as the idle speed is not adjustable does anyone have any suggestions?? Share this post Link to post Share on other sites
Ahl 4 Posted March 2, 2007 Moved post to the right section, XU service and maintenence... Share this post Link to post Share on other sites
Normski 1 Posted March 2, 2007 I have recently carried out an Mi16 conversion fitting a 1991 Mi16 engine and wiring loom into my 1991 205 1.9. One of many teething troubles I have is that the engine wont idle below about 1800rpm, as the idle speed is not adjustable does anyone have any suggestions?? There's too much air getting in, causing the high idle. You need to check for air leaks in the inlet system or a throttle problem i.e. not closing properly. Share this post Link to post Share on other sites
paul205mi16 4 Posted March 3, 2007 I had this problem-turned out tobe a small deposit or dirt/oil stopping the throttle butterflys closing, cleaned it off and now its spot on. Share this post Link to post Share on other sites
Guest twinbridge01 Posted March 3, 2007 Thanks. I will have a look. Share this post Link to post Share on other sites
