Richie-Van-GTi 74 2 Cars Posted March 1, 2007 Im dropping a 1.9 in my friends 1.6 this weekend to solve all his leaking issues in one swoop, plus a nice power increase. Will his loom be the same? Both engines are early non cat, non lambda engines. Only difference other than displacement is the coils. Just dont fancy fitting engine to find ecu wont work/fit. Share this post Link to post Share on other sites
jackherer 543 Posted March 1, 2007 The loom will work fine, if the coil plug is different use the coil that was originally used with that loom, and fit the inlet manifold to mount it if needed. Share this post Link to post Share on other sites
Guest Fangoria Posted March 1, 2007 it'll work fine, as said just use the original coil and inlet manifold if different, don't forget to use the the 1.9 ecu and afm Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted March 1, 2007 Ive already fit the right type of plenum for the other coil ready for the swap. Thanks for reasurance on the loom Share this post Link to post Share on other sites
