Guest ralphy1
Sunroof
Guest ralphy1
has anyone had problem with leaks around sunroof?1.9gti.it seems i may have a leak near the front mouldings. ;):P
ORB
that'll be the rubber washers then ;)
Guest ralphy1
that'll be the rubber washers then :P
cheers,will chek tomoz.if it ever stops raining!
Guest ralphy1
[quote name='ralphy 1.
looks like small leak above handle,used silicone under rubber middle.the only prob is..the runners are not sliding properly,one stays with the glass while the other doesnt move!dooooooh! : :)
