zilog 0 Posted February 27, 2007 I am planning on drilling new holes and moving the front suspension top mounts (on a 205 GTI) to the inner/rear about 10mm in each direction as this is all I suspect my konis with stock spring diameter allow. I have been told this should provice about 1 degree negative camber, and the increase of caster should also increase camber while cornering. Will this affect handling anything at all? I am not a racer but I would still like my car to perform as good as possible using the stuff I have handy. Share this post Link to post Share on other sites
Sandy 191 Posted February 27, 2007 Yes it does, but you need about 15mm to get 1 degree. Share this post Link to post Share on other sites
nick 3 Posted February 27, 2007 Why not do as everyone else does and fit 309 arms and shafts? Nick Share this post Link to post Share on other sites
GLPoomobile 958 Posted February 27, 2007 nick said: Why not do as everyone else does and fit 309 arms and shafts? Nick Answer...... Quote I am not a racer but I would still like my car to perform as good as possible using the stuff I have handy. Share this post Link to post Share on other sites
nick 3 Posted February 27, 2007 Good point...... Just seems a bit extreme to modify the shell when there is an easy bolt on solution, each to there own.... Nick Share this post Link to post Share on other sites
bren_1.3 1 Posted February 27, 2007 Quote Just seems a bit extreme to modify the shell when there is an easy bolt on solution, each to there own.... its only 3 small drilled holes, although you might be cutting it close with the outer bolt hole coming too close to the strut top hole. having said that. when those gay m7 studs shear no-one ever replaces them or drills them out so you could get away with just using the inner two studs. Share this post Link to post Share on other sites
zilog 0 Posted February 27, 2007 brens_1.9_wide_arch said: its only 3 small drilled holes, although you might be cutting it close with the outer bolt hole coming too close to the strut top hole. having said that. when those gay m7 studs shear no-one ever replaces them or drills them out so you could get away with just using the inner two studs. I was thinking of moving the studs in my spare set of top mounts, and maybe reinforce the entire thing with a sheet of metal to give it a more neutral MOT-friendly appeal. Share this post Link to post Share on other sites
bren_1.3 1 Posted February 27, 2007 Quote I was thinking of moving the studs in my spare set of top mounts, and maybe reinforce the entire thing with a sheet of metal to give it a more neutral MOT-friendly appeal. you'd only need to move the outer stud, the one closest to the wing. we prepare all our rally cars with thick plates welded to the strut tops, as they tend to bend upwards on rough surfaces and heavy landings. its a good idea to do so. Share this post Link to post Share on other sites
