sunil_2.0Fiesta
Electrical Problem, Headlights, Sidelights...
sunil_2.0Fiesta
My H reg 1.6 GTI has developed a problem. First the drivers front indicator stopped working, changed the bulb and relay and still the same.
Few days later Drivers headlight stops working and passengers sidelight. replaced bth headlights and sidelights and still the same.
Anyone know what i should check next. Is this a common problem?
Edited by sunil_2.0Fiesta
steve@cornwall
there should be an earth connection (yellow block,I think) mounted on the front panel, slightly inboard of each headlight. It's just a block of male spade connectors that individual earths plug into. these corrode,giving poor contact and may be able to clean the connections to cure these problems- or may disintegrate when you touch it, leaving the solution to your ingenuity ;) They may have little plastic "shower caps" fitted over them
sunil_2.0Fiesta
there should be an earth connection (yellow block,I think) mounted on the front panel, slightly inboard of each headlight. It's just a block of male spade connectors that individual earths plug into. these corrode,giving poor contact and may be able to clean the connections to cure these problems- or may disintegrate when you touch it, leaving the solution to your ingenuity :wub: They may have little plastic "shower caps" fitted over them
Cheers mate. I had look last night and they didnt look in that bad nick. i WD40'd them anyways and it made no difference. Any other ideas??
sunil_2.0Fiesta
Anyone got any other ideas?
Ive noticed the full beam dash light is always dimily lit and if you hit full beam the fogs come on and stay on until you completely turn the lights off
Phil H
take off the previously mentioned earth connector and clean the contact points back to bare metal on the body and teh connector, refit with a thin smear of vaseline.
sunil_2.0Fiesta
Im still getting the same problem.
Could somone tell me where all the earth points are on a 205 and ill check them all and give them a good clean.
Simes
The ones your concerned with are behind each headlamp.
sunil_2.0Fiesta
are you sure. All i can see is a yellow plug that goes down under the rad to the other headlight then goes into the bulkhead. Cant seem to see any earth points to the chassis coming off
sunil_2.0Fiesta
is this relay anything to do with the headlight?
sunil_2.0Fiesta
anyone???
Craigb
what are the wire numbers going to the relay ?
sunil_2.0Fiesta
what do you mean mate
Craigb
If you take a close look at the realy , the wires that are connected to it will have numbers printed on them .
fencer
mine is disconnected for some strange reason ... probably cos its not a GTI but i presume that should mean that it has got nothing to do with the headlights
sunil_2.0Fiesta
Ive sorted this now, well the headlights anyways. Steve was right in his first post about the block connector. I was just looking at the wrong connector doh. Noticed the one he was on about this weekend after id spent awhile cleaning up every other earth i could find lol
Front drivers indicator is still not working but at least the headlights are sorted. Gonna have a go at sorting the indicator out this weekend.
steve@cornwall
Check the bulb holder on the indicator, make sure the contacts are clean and gently prise the bottom (+) contact upwards to make sure its a good springy connection to the bottom of the bulb.
You could swap holders o/s to n/s first to check if this is the prob
sunil_2.0Fiesta
Ill give that ago. Thanks for your help mate :)
