5150maxie
Stereo Turning On And Off?
5150maxie
ive just finished testing my lights for mot and my stereo is going on and off with ignition on?all the lights worked is this an earth problem?if so where is the earth inside the car? plus theres is a relay ticking on the brake pedle when its going on and off? (the stereo i mean)
Edited by 5150maxie
sounds like a faulty alternator perhaps, have you got a multimeter you can use to measure the battery voltage with?
Faz85
Sounds like an earth problem to me, does the 205 take its earth from the aerial? I had a similar problem on a different car and it was due to a bad aerial connection.
5150maxie
its woking ok now,i will have a look tomorrow i think it an earth,thanks :(
Doof
Another vote for possible alternator fault. My stereo would turn off every time i pressed the brake pedal and this turned out to be the alternator!
