david932
Unlocking Ecu
david932
is there any way of unlocking a gti6 ecu if you have the ecu, engine loom and keypad but no wires to the keypad?
Richie-Van-GTi
if you grab a haynes or search online for the wiring schematics you should be able to make a mini lom for keypad fairly easily. If you do then you could use the keypad in the car with the ecu for extra security :ph34r:
david932
:) sounds good! i'll get on it
