djinuk
Carb Will Not Close Fully
djinuk
I have a standard 1360 tu engine in my xs, Ive had to fit a new carb onto it as the old one played hell. I have done this and the idel is turned very very low but the throttle wont close fully (open about 1/2mm) causing it to idel at around 2k plus. I have been told i need to pretension the spring on the throttle, anybody else done this, help needed :) Thank You DJ
stu_woac
have you got a pic of your carb from the top and the drivers side so I can have a look, spring on these are normally fine
