pee vee 1 Posted February 18, 2007 Hi all. just wondering what everyone does when they get rid of the OE seats in a 205 as reguards Seatbelts. im looking at getting some Cobra Imolas, and some side mounts for them. but looking at the original seat, the seatbelt buckle bolts onto the original Pug Seat subframe. so, how do you mount harness's with sidemounts/bucket seats? and can you use normal seatbelts with bucket/race seats?? as harnesses seem a bit much for road use!! Any info would be great! thanks! Phil (i did do a search but found nothing lol) Share this post Link to post Share on other sites
steve031286 0 Posted February 18, 2007 Are you looking at fitting 3,4 or 5 point harnesses? I have 3 points in my pug. i bolted one side where the orginal seat belt runner bolted to the chassis. The side (button side) to the seat subframe. and the top strapes to the rear seat belt top mount. Very safe! Looks wicked! steve Share this post Link to post Share on other sites
Jrod 7 Posted February 18, 2007 Go through the floor with an eye bolt and then a plate underneath the car. Can buy the plates on ebay etc for next to nothing. Share this post Link to post Share on other sites
pee vee 1 Posted February 18, 2007 Thanks guys! i'll be looking into it soon! Share this post Link to post Share on other sites
smckeown 1 Posted February 18, 2007 also combine a cage with harness bars Share this post Link to post Share on other sites
swordfish210 20 Posted February 18, 2007 (edited) i'm using securon 3-point harnesses and i bolted the rear mount in to the original hole for the rear seats as its probably the strongest mounting point on the car and i put a nut on the back of it, then i mounted the door side point in to the original seatbelt mounting bu the base of the b-pillar and for the last one i drilled a hole in the floor by the handbrake and put a bolt through there and made up some plates to go underneath which match the contours of the floorpan and then bolted them in with a nut as well. excelent Edited February 18, 2007 by swordfish210 Share this post Link to post Share on other sites
max0 5 Posted February 18, 2007 (edited) off topic - but do you have the seatbelt buckles still as i'm after a passenger late model one as its not keeping the belt in. Thanks Edited February 18, 2007 by max0 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted February 19, 2007 This is how I did it on mine. No problems so far. Graham. Share this post Link to post Share on other sites
tom_m 0 Posted February 19, 2007 (edited) I drilled a hole through the exhaust tunnel behind the handbrake and used the twinned rear seat belt buckles from the 306 which i bolted in with a strengthening plates. no problems so far and passed an mot with them like this. Edited February 19, 2007 by tom_m Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted February 19, 2007 off topic - but do you have the seatbelt buckles still as i'm after a passenger late model one as its not keeping the belt in. Thanks i had this problem a while ago mate. sorted it by spraying a s*ite load of wd40 inside and wiggling a screwdriver about then pressing the button loads, worked fine since Share this post Link to post Share on other sites
