Guest cossiecrew
Is The Mi16 405 Engine Identical To The Citreon......
Doof
a bx gti 16v yes, but an 8v exists so watch out :unsure:
steve031286
...bx gti engine
as above please :unsure:
The bx gti was the 1.9 8v where as the mi-16 is 16v. i think they did make a 16v bx though! i may be wrong.
steve
Edited by steve031286
steve031286
you got there first lol! so there is a 16v lol. :D
Guest cossiecrew
cheers guys are they both 160 bhp ? the 16v not 8 v
steve031286
I would amagine so! the engines are identical!
steve
steve031286
cheers steve
No worries! :unsure:
dont you dare break one of the last left!!!!
Guest cossiecrew
haha i would break it if it was the only one left
Spiky
ah ha,,,, so you know you not going to beat me around track, so you going for the bigger engine...pmsl ...lol
the different badges you might see on fast BXs are 'BX 19 GTI', 'BX GTI', 'BX 19 GTI 16v' and 'BX 16Valve". Only the last two have 16v engines, if it doesnt say 16v it isn't a 16v but some cars with GTI on the badge are 16vs so don't rule them out.
Ahl
The 16v engine has a much larger cam cover than the 8v engine, plus it also has 16v written on it, so have a look under the bonnet to be sure.
As said the BX engine is pretty much identical to the 405 mi16. It does however have hydraulic equipment all over it (that you can take off) and apparently the exhaust cam has a bit more duration to compensate from the power loss from the hydraulic pump. Should be a little better than the 405 engine, apparently. :ph34r:
Guest cossiecrew
you wont last long spiky these tracks have corners you forget ive seen you in action :ph34r:
steve031286
To be honest m8 i agree! the bx isnt that bad a car! im only talking abouth the gti's of course. There are far more mi-16 205s around than the bx. If you have found a mint one. keep it. i can imagine it will be worth more l8r.
When i was about 14 my best m8s dad took me out in his 1.9 gti bx. I was really impressed with what i was seeing.
I would h8 to brake a really mint one. His sold a couple of years l8r for only £700 i was gutted more than the owner lol.
steve :ph34r:
VisaGTi16v
BX 16valves fetch quite good money these days as so rare. If you do find one and its a late one, J reg I think, get under it as the BX got the 148bhp 1905cc 16v with a cat briefly! The 405 never had this as it moved to the 2 litre Mi16 but the BX stopped at that point, replaced by the Xantia. You dont want the cat one but there were so few sold then that it would be hard to find one!
