acox99 74 1 Cars Posted February 16, 2007 iv just rebuild my xu10 MI engine, and i have put the clutch on the flywheel, and the clutch release bearing is part of the clutch, but how do you mate it upto the box, its the clutch that came out the engine, is in good nick, i just cant get the fork onto the release bearing, im not using original gearbox, its from a 405 si, but i remember the original gearbox being a pig to seperate from the engine. Share this post Link to post Share on other sites
sonofsam 5 Posted February 16, 2007 @ a guess, that sounds like a 'Pull' type clutch, had one originally with my 2.0L turbo with bearing as part of the clutch cover plate. Is that the reason it will not mate with your box?! Share this post Link to post Share on other sites
acox99 74 1 Cars Posted February 16, 2007 Yep, its a pull type clutch with the bearing attached to the clutch cover, and i just cant get the gearbox to mate with the release bearing. Any tips to do it Share this post Link to post Share on other sites
sonofsam 5 Posted February 16, 2007 Well the next logical question is. Does the gearbox your trying to use, have a pull type system? Sorry I cant really help any further, as I ditched the pull type clutch as it did not mate and would not work with my 205 1.9GTI Be3 box. Share this post Link to post Share on other sites
PsychoSimon 0 Posted February 16, 2007 presuming you do have the pull type clutch arm in your gearbox, then to get the two to mate together you need to knock out the pin that holds the external bit of the release arm to the internal bit, then sort of hook the internal bit behind the bearing if you get me. nigh on impossible with the engine in the car in my opinion, but I know it can be done Share this post Link to post Share on other sites
acox99 74 1 Cars Posted February 16, 2007 is it possible to put a push type clutch onto the engine, as i have not got a pull type gearbox.....hense why it obviously doesnt work, has anyone got a pic of a pull type lever Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted February 16, 2007 yes I have a push type 215mm clutch on mine and thats from an mi16, alsom the 306 2.0 8v uses a push type clutch 215mm. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted February 16, 2007 It's not that bad a job at all in or out of the car, As said the pin needs to be knocked out so the cross shaft (Where the clutch cable attaches to the end of) can move to enable the fork on it to locate in the release bearing on the cover and slide the box on, If you have the hole in the front of the box you can look thru that to see if it's on or the later boxes it's a bit of a guess until you try it for the first time. Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted February 16, 2007 As you don't have a pull type gearbox, I suggest you replace the clutch with a 1.9Mi16 one. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted February 17, 2007 or swap the arm and holder off the old pull type box if its still available. Share this post Link to post Share on other sites
